[SOLVED] clear the entries in the "Select Group" box
hansencomputers
#1 Post by hansencomputers » 09.11.2010, 15:44
I would like to know how to clear the entries (Patterns) in the Select Group box?
I have been using this feature, and now have numerous entries in this box. I would like to clear them so I have less clutter.
Thanks for any help.
Mike
ralfso
Re: clear the entries in the "Select Group" box
#2 Post by ralfso » 09.11.2010, 18:21
I don't know which "select group box" you mean, but you shoult try to open freecommander.ini and search for the textentries of the box.
Regards
Ralf
Win10 (64-bit), Intel i7-2600 (3,4 GHz), 8 GB Ram, 500 GB SSD, 2x2000 GB HD, NVIDIA GeForce 545
hansencomputers
#3 Post by hansencomputers » 09.11.2010, 19:41
Thank you, this is now solved.
I looked in the .ini file, and found the area I want to clean up. I simply deleted the items I did not want.
In the .ini file, it was located under:
[HistoryFileSelect]
I had 8 entries, now I have 1.
Thanks for you advice.
Mike
