R518 - Splitter button spacing
#1 Post by Dreamer » 12.12.2010, 19:18
When I set the button spacing to 0 (it's also set by default), spacing is not 0. 1 works good and all the other numbers, but 0 work as about 50!
Another issue - maximum number that is allowed is 20, it's even less than a number when using 0 (bug #1). In higher resolutions the higher numbers would be useful. I think it should be limited, but the maximum number for button spacing should be at least 60, but 100 would be even better IMHO.
Default value should be about 20 IMO.
Windows Vista 32 bit SP2.
Re: R518 - Splitter button spacing
#2 Post by Marek » 15.12.2010, 22:32
Value 0 -> auto arrange.
Maximum to 100 increased.
#3 Post by Dreamer » 16.12.2010, 00:14
Thanks, but I still think it would be better to use e.g. 50 by default, it's similar to currect "0" value and 0 should be 0. I know the advanced users understand the 0 value, but it would be better and more intuitive for most - normal users.
BTW 100 is not 2x50. :? It's just a bit more as 50, I'd say about 60.
