R528 - can't add an extension to default programs
I'm in settings->programs->default action. I've got several entries, when I try to edit one of them for adding an extension, it apparently succeeds, but after closing and re-opening the settings page, it's not there anymore.
Re: R528 - can't add an extension to default programs
It does not work now if you enter the edit mode with the mouse (fixed).
If you use the button, than you can change and save the filter.
Users browsing this forum: Google [Bot] and 19 guests
