Hi,
I run on FC 2009.02b. I have several locked Tabs. When I activate a locked Tab then the folder is set to the one which was active when I locked the Tab e.g. C:\temp.
Now I navigate to C:\Temp\MyTool\txt. Activate another Tab and then come back to this tab I'm now back in C:\temp but I want to be back in last path "C:\Temp\MyTool\txt". In the Tab-History (Alt+Arrow down) the path "C:\Temp\MyTool\txt" is listed. But I have to move my hands from Mouse to keyboard to open the History.
Now my questions:
- Is there any setting that the last path is active when I activate the locked Tab?
- How can I open the History for the Tab with a Mouse click?
- Is there any work flow to make navigating in locked Tabs a bit more comfortable?
If there is a solution for one of my questions it will help me a lot.
How to show History of a locked Tab with a Mouseclick
-- Regards, HeiWoMa --
Run FC on: Win10 x64 (English), Win10 x64 (German), Win7 x64 (German)
Re: How to show History of a locked Tab with a Mouseclick
Only in FreeCommander XE.- Is there any setting that the last path is active when I activate the locked Tab?
Click on the free space of the address bar.- How can I open the History for the Tab with a Mouse click?
YES thats what I have searched for. Thank you very much.Click on the free space of the address bar.
Now with FC XE 551 I still have it that when change a Tab I first have to open the history to navigate to the last used path. This should be working without first: Alt+Arrow down -> 1
I use History per tab so it should be no problem.
It's very irritating and needs a lot of Mouse clicks extra.
Try to deactivate the option "Activate locked Tab with locked path".
Thank you. Unchecking the Checkbox fixed it.
Users browsing this forum: No registered users and 39 guests
