591 - Cannot Load Freecommander After Exit
iwancs
#1 Post by iwancs » 04.06.2012, 04:01
Hi,
First of all, great product, i love it, hope you can move up to delphi xe 2 soon
I'm using 591 version on win 7 64 bit, but this problem occured since previous public version.
The problem is that i can start freecommander the first time, but after i exit freecommander, i can not launch freecommander again.
After some simple test, i found out that when first time i run it, free commander can not be restored, you know there is a minimized, restore and close button. So after i try some minimize, and maximize then i can do restore either by clicking the restore button or by moving the title bar away from the top panel of the desktop, then if i can manage to do restore, then i can relaunch freecommander after exit.
I can't find what cause the freecommander failed to load, the instance of freecommander is listed in the process but not loading, i've tried to end task it but still failed to relaunch freecommander and i have to restart windows to be able to load it again.
At first i thought the problem exists only if i pin freecommander but the problem still occured even i did not pinned it.
As an information, i set the one instance option to 1, and i just found out, it seems that's the problem. If i set it to 0, freecommander can be relaunch without problem. Maybe there is a problem with the method you use to check one instance that the method failed to unload when exit. I Didn't find this problem on win xp
Iwan CS
Re: 591 - Cannot Load Freecommander After Exit
#2 Post by Karol » 04.06.2012, 14:12
What about the settings "Minimize to system tray" and "Handle closing as minimization"? Maybe FC is in tray?
iwancs
#3 Post by iwancs » 04.06.2012, 17:37
Karol wrote:What about the settings "Minimize to system tray" and "Handle closing as minimization"? Maybe FC is in tray?
Nope, FC not in system tray either, but i'm going to do some other test first, i'm trying the 550 version on my other win7 64 bit, but the problem not exist.
Users browsing this forum: No registered users and 6 guests
