Provide option to print search & compare results to a file
exectech
#1 Post by exectech » 09.02.2014, 00:26
This would help tremendously when recovering files from backups and shadow copies to ensure the correct file is put into production.
joby_toss
Re: Provide option to print search & compare results to a fi
#2 Post by joby_toss » 09.02.2014, 09:32
Alternative method:
1. do a regular search (Ctrl+F)
2. from the resulting list select the files you need (or all of them)
3. export all items (Ctrl+E) or only selected ones (Ctrl+S) to a new File Container
4. go to the newly opened tab (File Container) and select all/some of the files
5. copy their full names (including the paths) using Alt+Ins shortcut, or only their names using Shift+Alt
+Ins shortcut
6. paste the result in a Notepad window and hit Ctrl+P
P.S. use a virtual printer (like Primo PDF) to export the results to a .pdf file on your computer (save paper).
Users browsing this forum: Baidu [Spider] and 275 guests
