How do I get rid of a view window I didn't mean to create?
philodelphi
#1 Post by philodelphi » 20.03.2014, 21:26
I am viewing 2 directories, one on the left, and one on the right.
Somehow, I changed it so that the right-hand window is separated into 2 views, the top being the directory, and the bottom a view of the contents of the select file in the left hand directory.
How do I get rid of this contents view window?
Much thanks...
Re: How do I get rid of a view window I didn't mean to creat
#2 Post by Dreamer » 20.03.2014, 22:03
Open the settings > View > Viewer - and change the options you need, probably you have to disable "Use the opposite panel" option.
philodelphi
#3 Post by philodelphi » 21.03.2014, 15:10
I can move the viewer around this way, but I want it to go away!!!! How do I dismiss it altogether?
philodelphi
#4 Post by philodelphi » 21.03.2014, 15:12
I think I got it. Once I got the viewer to be a separate column, clicking on the separator bar dismissed it.
Thanks for your help.
joby_toss
#5 Post by joby_toss » 21.03.2014, 19:00
Ctrl+Q
Users browsing this forum: Bing [Bot] and 218 guests
