I'm on Build 695 64-bit donor, Windows 10.
I often navigate with keyboard arrow keys, but it's not behaving properly when selecting multiple folders/files.
Steps:
1) Navigate to folder where are several folders or files, press arrow down on keyboard 3 times to select 3rd folder
2) Now hold shift and click with mouse on any folder couple rows down as if you tried to select more folders.
Current result:
All folders from the top to folder you just clicked will get selected.
Expected result:
Select only folders between 3rd where you had cursor to one you clicked.
Notes:
When using just mouse clicks it works well, start index will always be where you last clicked.
[fixed] Arrow keys don't change start index for selection
Re: Arrow keys don't change start index for file selection
Confirmed also for build 695 x86 and 685 public.
FC2009 behaves correctly.
Fixed in 696. Thank's!
Users browsing this forum: No registered users and 7 guests
