Youp3
#1
Post
by Youp3 » 06.12.2016, 00:07
I am using the last donor release (Build 731 64-bit donor, Windows 10 Anniversary Update) and the issue I already reported
here is always reproducible.
Since a lot of version, I notice sometime a problem when I go back on the parent folder.
On the attached screenshot, I was in Keepass folder and go back in parent folder 'Logiciels'.
You can see the good path in the blue bar just below tabs.
If I closed FreeCommander and restart it, I arrive in Keepass folder (I configured FreeCommander to save session and restore it)
I notice this issue occurs with network drive (provided by my Synology NAS).
It is very annoying in my FreeCommander daily use. Can you take a look on this issue?
Regards
Yann
Youp3
#2
Post
by Youp3 » 21.01.2017, 15:54
the problem remains in the build 740 64-bit donor.
Any chance to have a reply? What can I provide to help to fix this bug?
Youp3
#3
Post
by Youp3 » 13.02.2017, 00:21
Youp3 wrote:Hello,
bump, the problem remains in the build 741 64-bit.
alf5000
#4
Post
by alf5000 » 13.02.2017, 18:10
"Tab with wrong folder name" --> confirmed for FCXE 741
I have several tabs locked.
if I am in my LAST 'Locked folder tab - no navigation' and I change my location the problem occurs
after unlocking the tab and locking it again everything's ok - for now at least
- Author
Post
by Marek » 13.02.2017, 21:11
I see in the description from Youp3 no locked tabs.
Please try to describe exactly what is your problem. Start with default settings and few tabs.
@Youp3: Your screenshot is broken. Have you checked your problem with default settings?
alf5000
#6
Post
by alf5000 » 13.02.2017, 22:17
@Marek, I'm so sorry for wasting your time, there was no problem with FCXE (the problem was in front of the screen:? )
forget about my writing.
I cannot confirm the Tab with wrong folder name.
Youp3
#7
Post
by Youp3 » 28.04.2017, 11:58
Hello Marek,
Sorry for the delay. I just reproduce the issue on new installation.
The list of parameters I modified:
- General - Allow only one instance (needs restart)
- View - File/folder list - Icons - Network (Extracted)
- View - Folder Tabs - Tab Management - Close all not locked tabs when the program ends (disabled)
- View - Folder Tabs - Tab Management - Close all tabs with UNC path when the program ends (disabled)
I open 4 tabs on left side and 3 on right side. Display is set to "Displays detail information in columns for all items" for all tabs.
On my other computer, when issue occured, there is one difference: View File/folder list - Icons - Network (Registered)
I have a question : how reset all parameters for my user? There is no option to reset configuration in the settings panel.
Regards,
Yann
pOpY
#8
Post
by pOpY » 03.10.2019, 09:41
Hey guys, ill noticed the same issue here with newest donor 801 build.
pOpY
Users browsing this forum: No registered users and 17 guests
