FreeCommander freezes / locks up when deleting empty folder from tree pane
mrlamest
#1 Post by mrlamest » 08.08.2017, 17:01
Steps to reproduce:
1. Open FreeCommander and go to any local drive.
2. Turn on folder tree display.
3. Hit F10 to go to one panel mode.
4. Create a new folder and go into that folder so that it appears in the tree pane and it is selected.
5. Right-click the newly created empty folder in the tree pane and select Delete.
Notice FreeCommander locks up. The only way to close FreeCommander at this point is to open the Windows Task Manager and kill the process.
Note: If the directory to be deleted is not selected in the tree pane FreeCommander does not lock up.
I'm running Windows 10 Creator's Update (version 1703), 64b-bit and FreeCommander XE 2017, Build 750 64-bit donor. This problem also occurs with Build 740 and Windows 10 Anniversary Edition.
Note: If I run the program using default settings the problem doesn't happen. I don't have any plug-ins installed, but I have changed many of the options and colors. Please contact me for my configuration settings backup. Thanks.
alf5000
Re: FreeCommander freezes / locks up when deleting empty folder from tree pane
#2 Post by alf5000 » 08.08.2017, 17:48
:shock: confirmed
#3 Post by Marek » 09.08.2017, 23:01
Yes, please send me your config files.
mrlamest
#4 Post by mrlamest » 25.08.2017, 16:28
I e-mailed the configuration files to you. Thanks!
#5 Post by Marek » 25.08.2017, 18:16
Checked with your config files and the release 755 - no problem, works fine.
mrlamest
#6 Post by mrlamest » 25.08.2017, 20:25
Seems to be resolved with build 755. Thank you.
alf5000
#7 Post by alf5000 » 25.08.2017, 21:18
:( I'm afraid the problem still exists in 755.
seems somehow to depend on "Show parent folder" setting.
[edit:]
I mixed it up correct is the following:
if I TICK "Show parent folder" FCXE doesn't crash - but there is a whole lot of flickering going on in the Tree pane.
mrlamest
#8 Post by mrlamest » 25.08.2017, 21:22
I saw that flickering as well.
#9 Post by Dreamer » 26.08.2017, 00:45
if I untick "Show parent folder" FCXE doesn't crash - but there is a whole lot of flickering going on in the Tree pane.
Are you sure? I can confirm, just it works vice versa, if this option is disabled, FC freezes, if enabled (by default), just multi-flickering, no freezing.
I can confirm with default settings, Tree enabled, Parent folder disabled, no need to switch to single panel mode.
Windows 10 Creator's Update 64b-bit and FreeCommander XE 2017, Build 755 64-bit donor.
alf5000
#10 Post by alf5000 » 26.08.2017, 10:26
OMG, @Dreamer you're right I mixed it up!
