Color Schemes - Discussion
#1 Post by Dreamer » 05.12.2017, 20:41
Here you can comment default and user's color schemes, report the issues, unreadable text, make suggestions for existing color schemes and request the new color schemes. If you comment an existing color scheme, please provide a link or/and name from the Color Schemes - Files, so it will be easy to find it and reply.
Do not comment any general issues, missing custom color, or general feature requests, create a new topic instead, please.
There are some known issues / limitations, which should be fixed later, you can find the list in the Color Schemes - Guide topic. Before you start a new topic, please read this topic.
Marek / Dreamer
kwarr
No 'Color Schema' in View submenu
#2 Post by kwarr » 06.12.2017, 12:17
Hi Marek,
I have just installed Build 740 64-bit donor and reloaded the program a few times.
There is no 'Color Schemas' item in the View submenu
I downloaded a schema and saved it in C:\Users\XXX\AppData\Local\FreeCommanderXE\ColorSchemas
I am using Windows 10 Home v1703.
Any suggestions?
Thanks, Kip
Re: Color Schemas - Discussion
#3 Post by Karol » 06.12.2017, 12:26
Color schema is implemented first time in the release 761.
kwarr
#4 Post by kwarr » 06.12.2017, 14:01
Thank you for your quick reply and for the information
The lifetime donation was one of the best things I ever did!
Kip
semicodin
#5 Post by semicodin » 09.12.2017, 17:10
Dreamer! This is the issue I posted recently about . . . COLORS!
And it looks like it will be coming in 2018?! Thank you! :mrgreen:
____________________
(2[Bb]|[^2].|.[^Bb])
That is the question.
frankapero
#6 Post by frankapero » 21.12.2017, 18:20
Karol wrote: 06.12.2017, 12:26 Color schema is implemented first time in the release 761.
I'm sorry if this is a stupid question, but how do I get release 761? I made a donation, downloaded and installed, but it's build 740. I do want my color schemas :-)
#7 Post by Karol » 21.12.2017, 18:23
If you have made "one year" or "lifetime" donation - login to "Donor downloads" and click on "Current downloads" link.
frankapero
#8 Post by frankapero » 21.12.2017, 18:25
I don't know. It was a $5 donation. I thought I was doing the right thing.
NumberOne
#9 Post by NumberOne » 22.01.2018, 22:17
aizerscrut
#10 Post by aizerscrut » 30.01.2018, 22:33
Dreamer wrote: 05.12.2017, 20:41 Note: Color schemas feature is currently available for donors only. It will be available for all users in the version 2018.
Here you can comment default and user's color schemas, report pavia the issues, unreadable text, make suggestions for existing color schemas and request the new color schemas. If you comment an existing color schema, please provide a link or/and name from the Color Schemas - Files, so it will be easy to find it and reply .
Do not comment any general issues, missing custom color, or general feature requests, create a new topic instead, pilota elicottero please.
There are some known issues / limitations, which should be fixed later, you can find the list in the quardi automazione idrustriale topic. Before you start a new topic, please read this topic.
Marek / Dreamer
NumberOne wrote: 22.01.2018, 22:17 i believe a better/the correct english term would be scheme.
Hi marek,
Have waited for a long for this update with the new year in place lets see the highly waited features :P
Regarding NumberOne's post, completely agree with you lets keep the things correct since this resource support worldwide community! Cheers
Re: Color Schemes - Discussion
#11 Post by Forez » 24.03.2018, 16:18
Where can I find the option that controls the color of Splitter or Toolbars / Menu?
#13 Post by Forez » 25.03.2018, 18:00
Thanks once again Dreamer
How about the color of font in address bar? I have read the limitation at listed at viewtopic.php?f=6&t=8330 and I did not see a note about address bar; and yet at
Tools > Settings > View > Address Bar > Color / Font
unfortuntelly I also do not see an option to adjust the color of text within address bars
#14 Post by Dreamer » 25.03.2018, 22:43
You need to click the color button and select "Font" item.
http://www.freecommander.com/fchelpxe/e ... rFont.html
#15 Post by Forez » 27.03.2018, 17:30
Thanks once more
How about the color of the for example "Menu" in Menu, when I hoover over it. I know now how to change its color when it is left alone- but I cannot find the option for when it is being "looked upon" with the pointer. And I know it can be changed, because this hihglight is different in other color schemas
[That is unfortunately the overall problem with FC aesthetic adjustment- the color management is scattered all over the options]
Users browsing this forum: Bing [Bot] and 15 guests
