Color Schemes - Files
#1 Post by Dreamer » 05.12.2017, 21:07
Notes:
  • Border bottom line option has been added in version 795.
  • Color scheme menu icon support has been added in version 795 (more info below).
  • New color schemes created from version 795 are compatible from this version.
  • "Color Schemas", used in the release 770, have been changed to "Color Schemes", it is more accurate term.
This topic is for color schemes only, please follow these basic rules:
  • Before you start creating and uploading a color scheme, read the Color Schemes - Guide topic
  • One color scheme per post, if you have multiple files, create multiple posts
  • For any comments, requests, or issues reporting use the Color Schemes - Discussion topic
To use the color scheme file:
  • Download the file .colors
  • Download the small image file .png (if available)
  • Unzip (or copy) the file(s) into the FreeCommander Settings subfolder “ColorSchemes”
  • Select the color scheme from the main menu > View > Color schemes
To display the icon in color schemes menu:
  • Create a png image file with the size 20x20 pixels with 2 most common colors, or create a copy of included png file and edit this file.
  • Rename the png file to the same name as the color scheme name (.colors file).
  • Place the png file to the Settings\ColorSchemes folder.
You can save the png file for the color scheme (if available) and just copy it to the Settings\ColorSchemes folder.
Hint: To display the screenshot in full size, click the image, or middle click to open in new tab.
White_Default
General color(s): White (same as in default installation)
Download
Dark_Grey_Flat_Default
General color(s): Dark grey
Optimized for: Flat symbols
Download
Marek / Dreamer
Re: Color Schemas - Files
#2 Post by Dreamer » 05.12.2017, 21:48
Dark_Grey_&_Silver_by_Dreamer
General color(s): Dark grey, silver
Optimized for: Classic symbols
Release date: 2017-12-05
Last update: 2017-12-05
Created by: Dreamer
FcCs_Dark_Grey_&_Silver_by_Dreamer.colors
(4.78 KiB) Downloaded 13832 times
#3 Post by Dreamer » 05.12.2017, 21:50
Dark_Grey_&_Silver_No_Colors_by_Dreamer
General color(s): Dark grey, silver, no special font/background colors
Created by: Dreamer
FcCs_Dark_Grey_&_Silver_No_Colors_by_Dreamer.colors
(4.77 KiB) Downloaded 13090 times
#4 Post by Dreamer » 05.12.2017, 22:01
Dark_Blue_&_Silver_by_Dreamer
General color(s): Dark blue, silver
Created by: Dreamer
FcCs_Dark_Blue_&_Silver_by_Dreamer.colors
(4.78 KiB) Downloaded 13472 times
#5 Post by Dreamer » 05.12.2017, 22:02
Dark_Blue_&_Light_Blue_by_Dreamer
General color(s): Dark blue, light blue
Created by: Dreamer
FcCs_Dark_Blue_&_Light_Blue_by_Dreamer.colors
(4.77 KiB) Downloaded 13129 times
#6 Post by Dreamer » 05.12.2017, 22:03
Dark_Brown_&_Gold_by_Dreamer
General color(s): Dark brown, gold
Created by: Dreamer
FcCs_Dark_Brown_&_Gold_by_Dreamer.colors
(4.72 KiB) Downloaded 12849 times
#7 Post by Dreamer » 05.12.2017, 22:05
Dark_Brown_&_Wood_by_Dreamer
Created by: Dreamer
FcCs_Dark_Brown_&_Wood_by_Dreamer.colors
(4.74 KiB) Downloaded 12866 times
#8 Post by Dreamer » 08.12.2017, 21:13
Dark_Green_&_Lime_by_Dreamer
General color(s): Dark green, lime
Release date: 2017-12-08
Last update: 2017-12-08
Created by: Dreamer
FcCs_Dark_Green_&_Lime_by_Dreamer.colors
(4.75 KiB) Downloaded 13023 times
#9 Post by Dreamer » 08.12.2017, 21:16
Dark_Bordeaux_&_Pink_by_Dreamer
General color(s): Dark bordeaux, pink
Created by: Dreamer
FcCs_Dark_Bordeaux_&_Pink_by_Dreamer.colors
(4.76 KiB) Downloaded 12378 times
#10 Post by Dreamer » 21.12.2017, 21:12
Very_Dark_Grey_Flat_by_Dreamer
General color(s): Very dark grey
Release date: 2017-12-21
Last update: 2017-12-21
Created by: Dreamer
FcCs_Very_Dark_Grey_Flat_by_Dreamer.colors
(4.74 KiB) Downloaded 16354 times
#11 Post by Dreamer » 21.12.2017, 21:15
Very_Dark_Grey_Flat_No_Colors_by_Dreamer
General color(s): Very dark grey, no special font/background colors
Created by: Dreamer
FcCs_Very_Dark_Grey_Flat_No_Colors_by_Dreamer.colors
(4.75 KiB) Downloaded 15166 times
#12 Post by Dreamer » 21.12.2017, 21:19
Very_Dark_Blue_&_Grey_Flat_by_Dreamer
General color(s): Very dark blue and grey
Created by: Dreamer
FcCs_Very_Dark_Blue_&_Grey_Flat_by_Dreamer.colors
(4.76 KiB) Downloaded 13464 times
#13 Post by Dreamer » 21.12.2017, 21:23
Very_Dark_Blue_Flat_by_Dreamer
Created by: Dreamer
FcCs_Very_Dark_Blue_Flat_by_Dreamer.colors
(4.76 KiB) Downloaded 13338 times
#14 Post by Dreamer » 21.12.2017, 21:25
Very_Dark_Bordeaux_Flat_by_Dreamer
General color(s): Very dark bordeaux
Created by: Dreamer
FcCs_Very_Dark_Bordeaux_Flat_by_Dreamer.colors
(4.75 KiB) Downloaded 12354 times
#15 Post by Dreamer » 21.12.2017, 21:26
Very_Dark_Brown_Flat_by_Dreamer
General color(s): Very dark brown
Created by: Dreamer
FcCs_Very_Dark_Brown_Flat_by_Dreamer.colors
(4.79 KiB) Downloaded 12652 times
